Mark S
fact 901 alum intermediate plate fit 71 911
Trans axle ? Getting ready to rebuild and have old aluminum 901 case any reason I can not use it to replace the mag plate in the 911 case and save some $. Any other parts I can swap to increase strength? Thank You.
i'm not sure but i think the aluminum and the mag intermediate plates are different thicknesses.
BMW 128i 73 rsr clone - sold 68 912 project to become 911r (almost done!) |
Absolutely a different thickness, so you cannot use it.
Out of curiosity, what are the serial and type numbers stamped into the cases you have?
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s Addicted since 1975 |
Mark S
Well so much for that. I will have to check #'s aluminum case it's in a pile in storage. I don't imagine you care about 911 mag case #'s?
#'s from 901, 902, 905 & 911 cases are useful. Not so for 915 & later at the moment.
Cast in date codes are also useful. Just trying to determine the highest serial of each type, and a few other things.
