-   -   Rear Window "Glazier Points" ? (http://forums.pelicanparts.com/porsche-911-technical-forum/552648-rear-window-glazier-points.html)
viejopatron 07-11-2010 04:19 PM
The rear window of my '71 coupe has 6 of these little bastards; 3 per side
Notice how the glass panel has "cutouts" for each position. My guess is that they preload the panel in the body recess. However, only side to side.
If anyone knows about these, I'm curious.
http://forums.pelicanparts.com/uploa...1278890031.jpg
http://forums.pelicanparts.com/uploa...1278890072.jpg
ossiblue 07-11-2010 05:30 PM
Those are the electrical connector lugs for the rear window defroster.
Trackrash 07-11-2010 05:49 PM
I don't remember anything like that on my 71 when I had the rear window out.
Kinda hard to tell from your pictures exactly where they are on the window channel.
Zeke 07-11-2010 06:46 PM
Yes, those are the ground connections.
robmog 07-11-2010 07:18 PM
+1 on the wiring connectors for the rear defrost.
and what a PITA it is to get the seal over the wires that connect to them.
i spent the whole day between that and fitting the aluminum trim pieces
joefrantz 07-11-2010 10:29 PM
PITA Illustrated
http://forums.pelicanparts.com/uploa...1278912501.jpg
