Party Member
Rear Window "Glazier Points" ?
The rear window of my '71 coupe has 6 of these little bastards; 3 per side
Notice how the glass panel has "cutouts" for each position. My guess is that they preload the panel in the body recess. However, only side to side. If anyone knows about these, I'm curious. ![]()
Gary 71 911T Miss Demeanor / 2013 Audi Q5 Hundeführer / 1995 993 Miss Adventure |
Those are the electrical connector lugs for the rear window defroster.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
Under the radar
I don't remember anything like that on my 71 when I had the rear window out.
Kinda hard to tell from your pictures exactly where they are on the window channel.
Yes, those are the ground connections.
+1 on the wiring connectors for the rear defrost.
and what a PITA it is to get the seal over the wires that connect to them. i spent the whole day between that and fitting the aluminum trim pieces
bob 1972 E pos correction: expensive pos someday.... "shut up and drive!" |
PITA Illustrated
Joe Frantz 73 911 T |
