AC repair help
So it is getting pretty hot around here, and the ac on my 1995 911 is weak at best. I have recharged it twice, up to about 35 psi. Even immediately after recharging it does not cool very well. After a few days (a week?) the pressure drops to 25 psi, or less. Any advice on how to proceed to find a leak, which hopefully may be somewhere that I could actually repair without extraordinary effort? I have a vacuum pump and AC guage manifold.
thanks.
Dave, in western MA. 1995 993 |
you may need to put a dye in the system and then use a black light to locate it. One thing you should replace is the drier tank.
Tony G 2000 Boxster S |
you can look for the wet spot. usually dirt will collect where the leak is if it is bad enough. another thing to do is use a sniffer. if the evap or expansion valve is leaking, sniffing the vents will let you know. found a bad evap in my brothers 930, goona check his volvo today.
86 930 94kmiles [_ ![]() 88 BMW 325is 200K+ SOLD 03 BMW 330CI 220K:: [_ ![]() 01 suburban 330K:: [_ ![]() RACE CAR:: sold |
