-   -   SC parallel flow condenser (http://forums.pelicanparts.com/porsche-911-technical-forum/552841-sc-parallel-flow-condenser.html)
chamilun 07-12-2010 04:25 PM
Ive searched and searched, but cannot find what I need:
where can one buy a replacement rear decklid condenser that is both slightly larger and the parallel flow?
1982 sc
thanks
equality72521 07-12-2010 05:12 PM
Why do you want parallel flow? Are you going to split in the winter?
khamul02 07-12-2010 05:16 PM
Someone has to make them as I think they come in some kits from AC guys offering them for 911s. But one such company will not sell just the rear condenser :(
Vmarch 07-13-2010 07:28 AM
1982 sc
thanks
Get a Behr replacement rear condenser so there will not be any fit issues. Replace all of the hoses and the drier and charge it up with R-12 or 134 but make sure your front condenser fans is working. Keep it as designed, it will never be like a new car but will take the edge off on a hot day. I jsut completely refurbished my system on a 79SC with a San 507 Compressor, new Hanza drier, new Porsche supplied expansion valve and all new barrier hoses. The system is charged with R-12 and gets out the cold air to the point that on an 85 degree day, I only turn the thermostat half way.
911pcars 07-14-2010 12:57 PM
Check with our host. I believe they carry a serpentine condenser; better heat transfer.
Sherwood
chamilun 07-14-2010 01:25 PM
what is more effective: a wheel well condenser, or increasing the size & efficiency of the one in the rear deck?
by the way, for anyone considering adding a fan to the rear condenser, its a great, easy & cheap upgrade. 7.5" spal fan moves a lot of air. Oddly enough, having the fan push (blow outward) seemed more effective than the puller configuration. I left it pulling air so that the engine wasn't robbed of intake.
KelogGes 01-04-2013 12:56 PM
I custom make Porsche 911 front and rear early model 911 micro-channel Parallel Flow Condensers
Josh D 01-04-2013 02:05 PM
Like this?
http://i906.photobucket.com/albums/a...asyover/c2.jpg
RetroAire has them
Josh D 01-04-2013 02:07 PM
Yeah, but only if you use the Porsche independent in Florida that you work for.:rolleyes:
khamul02 01-04-2013 02:51 PM
I think that is what this guy has been offering for awhile. I know his higher powered fan idea was "borrowed" by some of the other Porsche AC guys. I guess Retro can just chalk up this idea as being "borrowed" as well.
SilberUrS6 01-04-2013 03:41 PM
Reviving a year-and-a-half old thread? In the winter?
LOL.
