SC parallel flow condenser
Ive searched and searched, but cannot find what I need:
where can one buy a replacement rear decklid condenser that is both slightly larger and the parallel flow? 1982 sc thanks |
sudo apt-get purge 930
Why do you want parallel flow? Are you going to split in the winter?
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
Someone has to make them as I think they come in some kits from AC guys offering them for 911s. But one such company will not sell just the rear condenser
Tom Hutchinson 80 Targa / 81 Coupe / 71 Targa (in Porsche heaven) My Garage Build: https://youtu.be/H0n_NwEQVbs "If one does not fail at times, then one has not challenged himself." Ferdinand Porsche |
Get a Behr replacement rear condenser so there will not be any fit issues. Replace all of the hoses and the drier and charge it up with R-12 or 134 but make sure your front condenser fans is working. Keep it as designed, it will never be like a new car but will take the edge off on a hot day. I jsut completely refurbished my system on a 79SC with a San 507 Compressor, new Hanza drier, new Porsche supplied expansion valve and all new barrier hoses. The system is charged with R-12 and gets out the cold air to the point that on an 85 degree day, I only turn the thermostat half way.
Check with our host. I believe they carry a serpentine condenser; better heat transfer.
Sherwood |
what is more effective: a wheel well condenser, or increasing the size & efficiency of the one in the rear deck?
by the way, for anyone considering adding a fan to the rear condenser, its a great, easy & cheap upgrade. 7.5" spal fan moves a lot of air. Oddly enough, having the fan push (blow outward) seemed more effective than the puller configuration. I left it pulling air so that the engine wasn't robbed of intake. |
I custom make Porsche 911 front and rear early model 911 micro-channel Parallel Flow Condensers
Like this?
![]() RetroAire has them
'80 RoW 911 SC non-sunroof coupe in Guards Red It's not a Carrera.... It's a Super Carrera! |
I think that is what this guy has been offering for awhile. I know his higher powered fan idea was "borrowed" by some of the other Porsche AC guys. I guess Retro can just chalk up this idea as being "borrowed" as well.
Banned
LOL. |
