-   -   SC front end into '69 911t? (http://forums.pelicanparts.com/porsche-911-technical-forum/552907-sc-front-end-into-69-911t.html)
totallydude 07-12-2010 11:37 PM
I just purchased a 1969 911t.
I was wondering if the front end from an SC will bolt in? I want to use the turbo tie rods, suspension, brakes, etc...
Also, will the torsion bars for an SC also fit on my '69?
thanks in advance for any input!!
Chuck Moreland 07-12-2010 11:50 PM
The whole thing will drop right in.
You can also mix and match parts, but you have to choose the right combination.
totallydude 07-13-2010 12:30 AM
thanks
Vmarch 07-13-2010 07:22 AM
Just buy an SC, don't modify a 911T its worth more in its original state any day.
Matt Monson 07-13-2010 07:26 AM
An SC brake, torsion bar and sway bar conversion is going to have pretty much zero impact on the value of a '69 911t. I suspect you think he's talking about putting impact bumpers on the car. Read it again. ;)
totallydude 07-13-2010 08:10 AM
Sorry I should have been more clear. Yes I only plan to use the SC brakes, torsion bar, sway bar and front shocks. Actually I have the entire front clip from a wrecked SC and was hoping to just unbolt my front and bolt the SC stuff in..
Also upgrading master cylinder and going power assisted brakes.
I understand the torsion bars are the same.
Trackrash 07-13-2010 01:46 PM
You may want to research this before you start buying parts. There are differences.
The brake calipers and rotors are bigger. Which may have some effect on braking, especially if you are using the 69 master cylinder.
The biggest problem will be the sway bar mounts are different.
The strut to ball joint attachment is different, but if you're are using SC struts and a-arms it won't matter.
SC's came with different struts and shocks,(Boge, Koni or Bilstein) which may make a difference to you.
Flieger 07-13-2010 05:17 PM
This issue was solved at post #2 by Chuck. The front suspension bolts right on. He already has the whole SC front end.
jwetering 07-13-2010 05:41 PM
Dude, did you totally buy that 69 from tht Ozzie in Bby?
A friend and I looked at that car and figured it was not a bad deal. It needed more work than we prepared to put into it though.
If it is the same car, good luck with it. There's no doubt it has huge potential.
