-   -   Idle speed slows when removing oil cap (http://forums.pelicanparts.com/porsche-911-technical-forum/553051-idle-speed-slows-when-removing-oil-cap.html)
maxman 07-13-2010 06:50 PM
When I remove my oil cap to check the oil (car running, motor warm ;), the motor slows down to a little bit rougher idle. The instant I put the cap back on, it idles right back up.
Normal?
~Max
Porschedr. 07-13-2010 06:53 PM
Depending on how bad it is, it's normal.
Also possible vacuum leak.
nineball 07-13-2010 06:56 PM
same thing happens on my perfectly running SC.
maxman 07-13-2010 07:00 PM
Could have something to do with my slightly poor cold idle? When the car is stone cold, it takes a few minutes before it "finds it's idle". After first starting, It will rev, then slow down to practically stopped, rev again and repeat, gradually smoothing out to a smooth idle after a couple of minutes. Once it's warm, it idles great (when the oil cap is on ;)
Porschedr. 07-13-2010 07:09 PM
I don't think so, honestly. You're inducing a vacuum leak when it's removed. It is normal to screw with the idle when removed.
brads911sc 07-13-2010 07:10 PM
Normal
equality72521 07-13-2010 07:11 PM
Check valve is missing in vent tube to oil tank.
maxman 07-13-2010 07:13 PM
equality72521, Can you provide a little more detail? I'm not familiar. Sorry to be so unaware.
brads911sc 07-13-2010 07:15 PM
not true. mine always idled lower with cap removed... and I had check valve installed. Actually if it doesnt idle lower it means you have a vacuum leak somewhere. idling lower is normal. Unless its stalling out, there is no real issue.
equality72521 07-13-2010 07:21 PM
The hose connecting the crankcase to the oil reservoir is supposed to have a check valve so you don't introduce a vacuum leak when removing the oil cap. These end up missing so you end up with idle issues when the cap is removed.
longhornchris04 07-13-2010 07:49 PM
small drop - normal... should be a non-issue if your idle is set right.
large drop or stall - missing the check valve
no drop - you have a bigger vac leak somewhere in the system and the induced vac leak doesn't change anything
maxman 07-13-2010 09:36 PM
Thanks longhornchris04.
I think I'm definitely in the small drop category. Sounds like its nothing to worry about.
crustychief 07-13-2010 09:46 PM
Small drop normal.
NewfieMZ3 07-13-2010 10:28 PM
normal......don't panic
maxman 07-13-2010 11:04 PM
Not panicking, just curious :)
Thanks for all the responses. Very helpful.
dshepp806 07-14-2010 02:18 PM
small drop=normal.......same here.
Doyle
mikesride 07-14-2010 04:06 PM
Uuuugh
Uuugh I may have an issue then.......mine speeds up and the small amount of hunting it sometimes does goes right away. Vac. issue of some sort maybe?
Mike B
longhornchris04 07-14-2010 05:15 PM
Mike... I'd start looking for vac leaks...
On CIS, hunting is a sign of over-rich. Then again, a vac leak should add more, not less air, so it may be something else.
Scott Douglas 07-14-2010 05:45 PM
In Mike's case it makes perfect sense if he has an over-rich condition. It causes the idle to hunt but when the oil cap is removed it goes lean and the idle comes up and settles down.
I'd say he something else causing the problem. Don't know what it may be but I'd bet it's not a vacuum leak.
Hodgey 07-14-2010 06:31 PM
Originally Posted by crustychief (Post 5453314)
small drop normal.
+1
