Idle speed slows when removing oil cap
When I remove my oil cap to check the oil (car running, motor warm
, the motor slows down to a little bit rougher idle. The instant I put the cap back on, it idles right back up.Normal? ~Max |
Depending on how bad it is, it's normal.
Also possible vacuum leak. |
same thing happens on my perfectly running SC.
- He gave his father "the talk" - Once while sailing around the world he found a shortcut - He taught a german shepard how to bark in spanish He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends. |
Could have something to do with my slightly poor cold idle? When the car is stone cold, it takes a few minutes before it "finds it's idle". After first starting, It will rev, then slow down to practically stopped, rev again and repeat, gradually smoothing out to a smooth idle after a couple of minutes. Once it's warm, it idles great (when the oil cap is on
I don't think so, honestly. You're inducing a vacuum leak when it's removed. It is normal to screw with the idle when removed.
Normal
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. |
sudo apt-get purge 930
Check valve is missing in vent tube to oil tank.
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
equality72521, Can you provide a little more detail? I'm not familiar. Sorry to be so unaware.
not true. mine always idled lower with cap removed... and I had check valve installed. Actually if it doesnt idle lower it means you have a vacuum leak somewhere. idling lower is normal. Unless its stalling out, there is no real issue.
The hose connecting the crankcase to the oil reservoir is supposed to have a check valve so you don't introduce a vacuum leak when removing the oil cap. These end up missing so you end up with idle issues when the cap is removed.
small drop - normal... should be a non-issue if your idle is set right.
large drop or stall - missing the check valve no drop - you have a bigger vac leak somewhere in the system and the induced vac leak doesn't change anything
Don't Lift... Don't Lift... Don't Lift ![]() ![]() ![]() '75 Targa in "Arrest Me" Red, 3.0SC ('79) engine, Bilsteins, Turbo Tie-rods, SSIs into 2-1 M&K muffler... and looking for my next upgrade. |
Thanks longhornchris04.
I think I'm definitely in the small drop category. Sounds like its nothing to worry about. |
Small drop normal.
A nose heavy airplane flies poorly, a tail heavy plane flies once. |
normal......don't panic
1984 911 Coupe 2007 Z4 M Coupe 2008 Cayman S 2004 M3-Alpine White(sold) 2002 M Roadster (sold) |
Not panicking, just curious
![]() Thanks for all the responses. Very helpful. |
small drop=normal.......same here.
Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
Uuuugh
Uuugh I may have an issue then.......mine speeds up and the small amount of hunting it sometimes does goes right away. Vac. issue of some sort maybe?
Mike B
I've driven alot of crap to get here man! |
Mike... I'd start looking for vac leaks...
On CIS, hunting is a sign of over-rich. Then again, a vac leak should add more, not less air, so it may be something else.
In Mike's case it makes perfect sense if he has an over-rich condition. It causes the idle to hunt but when the oil cap is removed it goes lean and the idle comes up and settles down.
I'd say he something else causing the problem. Don't know what it may be but I'd bet it's not a vacuum leak.
Scott '78 SC mit Sportomatic - Sold |
Neil 1987 Carrera, Grand Prix White, 2009 Carrera C4S, Meteor Grey Metallic (X) [B] 2011 BMW X5[B] 'Success is not final, failure is not fatal. It is the courage to continue that counts' |
