mikesride's Avatar
Stance / ride height question
My 82 sc has sat like this since I've owned it. Its my first 911 and one of very few in my home town ( nothing to compare it to ) I was doing some hard driving at a ralley last weekend and as I drifted thru a corner my driver front fender caught the tire!! Chomped the tire good and pulled down and out on the top lip of the fender well. Was able to fix the fender without having to repaint but is my car sitting to low? Or do you guys who drive hard roll those inner fender lips up and in? thanks
Mike
I've driven alot of crap to get here man!
Old 07-14-2010, 03:56 PM
Northern Motorhead
wildcat077's Avatar
Ride height looks perfect ...
Maybe you will need to go with stiffer torsion bars and shocks for spirited driving !
It's also a good idea to roll your fenders for prevention.
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 07-14-2010, 04:06 PM
Oh Haha's Avatar
Ride height and rake look fine. You could use the front torsion bar adjusters to raise the front a little. Do it the same amount of turns on each side and you shouldn't need to worry about alignment.
My DS front tire caught the inner fender lip BUT good a couple of years ago. I tried fixing it but ended up cracking the paint.(Body shop fixed that withthe deer repair.)
As suggested, new shocks will help in the handling, especially if yours are old.
Pacific Blue
Wayne
Old 07-14-2010, 05:14 PM
Dial in as much front neg camber as possable (probably about 1.5 deg). Might give you up to .5" more clearance depending on where you are at.
I ran 205/55/16's on 7" rims w front fender 25.25" from the ground w stock fenders, not rolled, and no clearance issue at all. Many track hours on an 85.
Old 07-14-2010, 06:54 PM
racer's Avatar
1) The car is sitting below factory ride height, but it looks better than factory
2) DS will always catch first on the tire.. in part because there is less room on the DS than on the passenger side. I'd suggest rolling the fender lips on both sides.
3) Figure out how old some of those suspension components are.. and then consider at least OEM replacements, if not something a bit stiffer and better suited for your "spirited" drives.
Past:
2000 Boxster 2.7, 1987 944, 1987 924S
1978 911SC, 1976 914 2.0, 1970 914 w/2056
Old 07-14-2010, 07:00 PM
