Poll: Which engine?
Poll Options
Which engine?
andrew15's Avatar
Engine choice for new project - 68 hot rod with ST flares
I'm embarking on a new project and wanted some thoughts on an engine for it. The car is a 68 911 with st style flares, fiberglass bumpers and hood, etc. Because it's already a sort of hot rod, I'm wrestling with the engine to fit.
I have a choice of:
1) stock 3.2 - but would need to do a valve job
2) 2.5 short stroke with S cams and webers - new parts, but needs to be assembled.
3) original 2.0 - running, but a 2.0
Either way, it's going to be fit to a new 901 box - I just like the 901 shift pattern. Cost isn't really an issue as I have all the engines just sitting here.
Andrew M
1970 911E - track / weekend car
1970 911S - under restoration
1986 930 Slant Nose - fun car
Current used parts for sale
Old 07-16-2010, 06:43 AM
Grady Clay's Avatar
Andrew,
My vote: 2.5S
Put a steel bumper back on the front (preferably the ‘72S version).
Make great effort to lighten everything in the rear.
Install LWB front suspension and steering.
Install the normal suspension up-rates but make sure you maintain lots of suspension travel.
With the standard 5-speed, you have good AFMSX gear ratios.
Depending on your driving, there are other choices.
Drive & enjoy.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 07-16-2010, 07:23 AM
andrew15's Avatar
Thanks Grady - i'm really happy with the 2.6 in my 70E and am leaning towards the 2.5 for the 68
AM
Old 07-16-2010, 02:57 PM
Hey Andrew, you don't even have it yet
And if you want to skip using the ST front flares, I do have a set of R Fibergalss Fenders, or you can fix up the original steel ones. And I have a original SWB front steel bumper that I welded the trim mounting holes up, it is pretty cool and would give you a real neat, smooth look. would take a bunch of work to use with the ST fenders though.
Robert
Currently Porsche less (but the wife has 2)
Old 07-16-2010, 05:10 PM
Size matters
Rich Kessel
79 R.o.W. 911 SC
Old 07-16-2010, 06:55 PM
