-   -   Has anyone gone with smaller diameter wheels in the front. (http://forums.pelicanparts.com/porsche-911-technical-forum/553600-has-anyone-gone-smaller-diameter-wheels-front.html)
sailchef 07-16-2010 03:04 PM
Just wondering.
Its a question I've been meaning to ask for a while.
What are the pros and cons. Has anyone done it.
racer 07-16-2010 04:57 PM
It might make more sense to go with a smaller diameter rear to affect a gearing change. Not sure going to smaller fronts would do much, unless its a cheaper way to create a change in the vehicles rake (front to rear).
Peter Zimmermann 07-16-2010 05:52 PM
When I built my '81 SC for PCA Club Racing I went to 10 x 17 rears, and used 8 x 16 fronts - worked fantastic.
http://forums.pelicanparts.com/uploa...1279327936.jpg
sailchef 07-16-2010 06:10 PM
That was one thought.
sailchef 07-16-2010 06:15 PM
Peter, thanks for the picture.
I have seen your car posted here several times and was pretty sure it wasn't an illusion.
I figuered that it would probably turn quicker with the larger diameter rear trying to run over the smaller front.
If that makes any sense.
efhughes3 07-16-2010 07:07 PM
Wheel diameter does not necessarily effect outside diameter. 17" tires typically will have lower aspect ratio numbers than 16's keeping the OD's similar.
Bill Verburg 07-17-2010 04:58 AM
Originally Posted by sailchef (Post 5458031)
Just wondering.
It would depend on what your goal is.
a bigger wheel can accommodate bigger brakes
a bigger wheel of equal width can run a lower profile tire that will run at a lower slip angle that will generate more grip and run cooler
