1980 911 SC
Has anyone gone with smaller diameter wheels in the front.
Just wondering.
Its a question I've been meaning to ask for a while. What are the pros and cons. Has anyone done it.
Life's a Beach |
It might make more sense to go with a smaller diameter rear to affect a gearing change. Not sure going to smaller fronts would do much, unless its a cheaper way to create a change in the vehicles rake (front to rear).
1970 914-6 Past: 2000 Boxster 2.7, 1987 944, 1987 924S 1978 911SC, 1976 914 2.0, 1970 914 w/2056 |
When I built my '81 SC for PCA Club Racing I went to 10 x 17 rears, and used 8 x 16 fronts - worked fantastic.
Keep the Shiny Side UP! Pete Z. Last edited by Peter Zimmermann; 07-16-2010 at 05:55 PM.. |
1980 911 SC
That was one thought.
Life's a Beach |
1980 911 SC
Peter, thanks for the picture.
I have seen your car posted here several times and was pretty sure it wasn't an illusion. I figuered that it would probably turn quicker with the larger diameter rear trying to run over the smaller front. If that makes any sense.
Life's a Beach |
Wheel diameter does not necessarily effect outside diameter. 17" tires typically will have lower aspect ratio numbers than 16's keeping the OD's similar.
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
a bigger wheel can accommodate bigger brakes a bigger wheel of equal width can run a lower profile tire that will run at a lower slip angle that will generate more grip and run cooler
