SC suspension upgrade ?
I am trying to prioritize expenditures for upgrading my 78SC suspension. I am looking for autocross/track ed improvement as well as general improvment in handling on our local twisty country roads. The 78SC is essentially as delivered (hell it even had the air pump on it!) except for the proper chain tensioners/blowoff valve etc.
I would appreciate the groups thoughts on what to do first on a moderate budget (<1200$). I do have new tires on order but was thinking: 22/28 Torsion bars Weltmeisters complete bump steer kit w/turbo tie rods ??? Also looks like the job replacing the torsion bars is pushing my skill limits...I read Waynes book...4 mechanics.... Richard
Richard Lane 1978 911SC 1973 "Clean" RS clone |
If you still have the stock tie rods, dump 'em. Get the turbo tie rods, and get a stable energies 3 point strut tower brace. There is one on rennlist for $128. All this will cost you $250 or less, and will make a remarkable improvement.
The new wheels and rubber (I am assuming 17" with Kumho's or something) will make the biggest difference. Let us know what you decide. Beyond what I have done above, I will probably be on this same path next year. Magilla |
Richard,
I believe the prevailing thought on suspension upgrades on our cars follow this order. This assumes everything is working fine in the first place. 1. Adjust ride height (+ adjust steering rack) 2. Upgrade torsion bars 3. Upgrade shocks 4. Upgrade sway bars 5. Install strut bar 6. Upgrade tie rods Items 5 and 6 are a tossup. Add corner balancing before alignment is needed (items 1, 2 and 6). It also depends on the time interval between each upgrade. Add improved/bigger/wider wheels and tires at any point. The specific details of each item can be found in the archives. Sherwood Lee http://members.rennlist.org/911pcars |
I did the following on my stock 78SC, and each has its own performance value. But here it goes in the order of preference, IMHO:
All new bushings (a-arm, rear swing plate and sway bar) After 24 years the rubber is probably worn just by sitting there. About $125.00 and provides a more precise ride. Pretty complicated an time consuming but a DIY project. Torsion bars 22/28 about $350 - 400 provides much better cornering. More complicated at teh rear but doable with some mech ability and Waynes book. Turbo tie rod ends about $125 - 150. More precise feel to steering. If your are original, they are worn. Need a special tool to remove exiting tie rod ends. All the above will require an alignment so its is best to do all at onceGet the car lowered and cornerbalanced at the same time. With the exception of replacing worn out rubber,this will probably provide the best results. About $225 - 275. Camber strut brace. Bruce Anderson states this provides negligable benefits on torsion bar cars. I have to agree for street use. Haven't tracked the car yet. About $140 - 200. Don't forget the shocks, if they are original they are worn. About $400. I probalby forgot other items.
Good input guys...I had not considered the camber plates but they make sense.
Thats what makes this place so good is to have input from other folks who have been there and done that!
If you upgrade your sway bars, don't forget to beef-up your mounting points at the rear. Otherwise, they will eventually break.
pbs911: I didn't need any special tools to remove my tie-rods, just an ordinary pickle fork. 11$ at any auto store. |
Schleprock
Pickle fork works great for outer rod end removal, but if the fork is the wider opening kind (some say pitman arm removal or tie rod removal) it might wreck one of the rod ends like mine. No big deal as the turbo kit has new outer ends. Just thought i'd mention that if someone were to want to save their rod ends. Probably have to then use one of these? Just my opinion/experience
Kevin L '86 Carrera "Larry" Last edited by KTL; 01-30-2002 at 12:27 PM.. |
KTL Wrote about the nut with four indentions. I have removed them from both my cars and a couple of friends cars with a flat chisel to break them loose and used a pair of chanel-locks to screw them off. The chisel did not cut into the nut but a little and I could have re-installed them, but installed turbo ends instead. I use some blue lock- tite and large open end wrench to put the turbo tie rods back on. Good luck! Duane
Duane '03 M3 Coupe, '65 Mustang 2+2, '72 Cherokee 140 |
Replace the shocks with either Konis or Bilsteins - big improvement. Larger torsion bars - I use stock 19 front and 27 rear on my 87 Carrera. It's terrific for the street but I plan on going to 22/29 mainly for the track. While you're doing that, might as well replace the anti-roll bars and bushings. Replace those silly stock bar mounts with heavy duty because they will break whether you change the bars or not. Lower the car to at least euro height or less. Put good rubber on the rims. Finally, get a really good alignment from a pro.
So, lets add up the costs.. Shocks $450 Torsion bars $450 Bushings $100 New sway bar mounts $200 Good alignment $120 Good rubber $400 Anti-roll bars $500-$1500 Strut brace $150 but not needed Since the proposed mods exceed the $1200 budget, just go with the stuff that gives most bang for the buck. I would go with shocks, torsion bars, rubber, and the alignment. Have fun.
