HarryD's Avatar
Making Muffler Straps
I recently obtained a Stock Leistriz Muffler for my car to replace the ANSA I have now. I knew I needed some straps to mount the muffler, but at roughly $40 (used)to over $100 (new), I figured I could make my own for much less.
I was able to obtain some scrap 1" wide Stainless steel strip material. I used some of it to to make 4 reinforcing Els. The rest I used for the strap itself.
I cut the 1" wide strip into 2 ea 23" long strips. I marked 1" from each end for the flange.
I then placed each end in my vice to bend the flange ends.
I then attached each of the Els to the flange ends with 2 pop rivets.
I then drilled a hole in each Flange end for the Muffler Strap retaining Bolts and Nuts.
Time spent - 2 hours.
Cost - $10 (mostly for the Stainless steel nuts and bolts).
Satisfaction of making it myself - Priceless (but I effectively paid myself $45/hour )
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 07-02-2010, 02:09 PM
steely's Avatar
Nice job Harry! You get points for re-cycling too, but I think you gave yourself a terrific break on the price, I usually charge myself $60/hr (weekend rate). :-)
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 07-02-2010, 05:42 PM
Hilbilly Deluxe
emcon5's Avatar
I used a HVAC duct hanger from the hardware store. I think I spent about $2 on it.
82 911SC Coupe
GTI Cup #43
Old 07-02-2010, 08:21 PM
Very Nice!! I took the short cut and used SS hose clamps.
1986 3.2 Carrera
Old 07-03-2010, 04:59 AM
HarryD's Avatar
Well, they seemed to work!! See them installed here: Bye Bye ANSA ... Hello Stock Muffler
Harry
2020 MB E350 4Matic
Old 07-31-2010, 03:05 PM
