91C2wrencher's Avatar
Red face Oops! oil change over-fill help?
Did my my pre-summer oil change today and got about a half qt. to much into her. Any quick and /or easy way to get out about a quart of oil?
Old 06-29-2001, 01:40 PM
mideastmafia's Avatar
Send a message via AIM to mideastmafia
Post
put your mouth around the filler and SUCK!
drain it out thru the drain hole.
SHAUN
Old 06-29-2001, 01:41 PM
TJM Carguy's Avatar
Send a message via AIM to TJM Carguy
Post
Did that once, too by accident on the '67. Do what mideastmafia said!
Old 06-29-2001, 01:44 PM
Post
actually...
knowing how 911s are, you will probably loose about 1 quart to the garage floor when you are asleep tonite.
SHAUN
Hilbilly Deluxe
emcon5's Avatar
Post
When this happened to me, I bought some clear tubing from a hardware store, and siphoned some from the fill tube. Stored it untill the car had bur... er "consumed" enough to add it back.
Tom
82 911 SC
Old 06-29-2001, 02:29 PM
Send a message via Yahoo to tmctguer
Post
this probabably sounds crazy.........but, i use my wife's turkey baster. it has a rubber top and a long plastic tube. it fits right into the oil tank and it pulls out about 1/8 quart per squeeze.
of course, she almost killed me the first time she caught me doing it the first time.
come to think of it, the Thanksgiving turkey seems to taste a bit better ever since i started using this technique.
Old 06-29-2001, 02:54 PM
Post
how far is the tank from the filler on the 911!!?!? on the 944 it is a long narrow tube that goes down into the block. you could only reach down there with a hose. if you wanted to use a turkey baster you would have to get one so long and slim that it would work good for giving the turkey enimas.
SHAUN
Old 06-29-2001, 03:05 PM
Steve F's Avatar
Wink
The turkey idea is good but this problem and other oil related filling and emptying situations,your local auto parts sells whats called a suction gun.Looks like a grease gun,but has a clear hose at the end and you just stick it what you what sucked up and draw the handle back und Valaaa, out she comes.It's only about $10 and your wife won't want to use it for the turkey! Everybodys happy.
1967 912 "in progress"
Old 06-29-2001, 03:17 PM
Rustbucket's Avatar
Post
Uh oh....too late.
It's already summer.
Clint
73T mfi coupe
Old 06-29-2001, 03:39 PM
