Stock Brakes for 78 911SC?
I was wondering if ATE made the calipers for the stock brakes on a 1978 911sc?
Were they single or 2 piston?
Old 07-24-2010, 12:42 PM
pete3799's Avatar
Not sure if ATE made them but they make the rebuild kits.
They're 2 piston calipers.
Pete
79 911SC RoW
Old 07-24-2010, 12:55 PM
Thanks !!!
I found a pair of ATE rear calipers with vented & drilled rotors in the garage.
I'm thinking they might be aftermarket.......
Old 07-24-2010, 12:57 PM
theiceman's Avatar
I have a 78sc .. single caliper ..
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 07-24-2010, 02:05 PM
Stock SC brake calipers.........
There are two (2) pistons in the brake caliper of SC's front and rear. Each piston sitting behind the brake pad. Depending how people count or call them. For example, stock 993 brake calipers have total 4 pistons per brake caliper yet I see some people refer them as two-piston caliper. Maybe someone could clarify this confusion if any. Thanks.
Tony
Old 07-24-2010, 03:03 PM
Bill Verburg's Avatar
SC used iron calipers from ATE, 2 piston, here's front and a rear
Bill Verburg
Old 07-24-2010, 03:11 PM
Tony
993 used 4 piston calipers from Brembo
most 964 used 4piston f/r but there were some early C2 that used 2 piston rears
there is a cheaper 1 piston sliding caliper design that is used on most other cars on the road but not Porsche
Bill Verburg
Old 07-24-2010, 03:13 PM
woland's Avatar
So
from where my 1980 SC calipers come from?
(I found it mounted. They work fine)
Are they from a 964 too or a 930?
Paolo from Alps
1980 911 Targa SC 3.0 - Silver metallic
1980 Ducati Pantah 500 - Red
1989 Yamaha 500 "Tracker"
Old 07-25-2010, 08:00 AM
Originally Posted by woland View Post
So
those are not stock 911 calipers, there are many possible places that they could have come from but the most likely source is from the front of a 964, the rotors are probably from a 3.2 Carrera
Bill Verburg
Old 07-25-2010, 12:30 PM
Thanks !!!
I remember seeing the "P 75" casted on them too.
The ones I have are painted black and look new.
Maybe they are rebuilt ???
Old 07-26-2010, 11:31 AM
