Air Conditioning
Car is 1979 911 SC, with add on A/C years ago. Recently converted to R134A coolant. Have noted that when AC not on volt meter shows 13-14 volts. When AC on volt meter only shows 11-12 volts. Any ideas what may be going on here? Is there a potential problem? Lynn
lynn, 68 912 coupe, 2011 Cayman base
Old 07-23-2010, 01:58 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Voltage across battery terminals, corret?
Voltage regulator may be bad. Voltage readings should vary in the hundredths of volts not tenths or half volts. This assumes you have that big of a range.
As to dropping below 12 volts, I am not sure - not an auto electrician. Seems that voltage should not drop below 12V, ever, with a functioning alternator.
Old 07-23-2010, 02:15 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
I agree, the voltage on our '86 holds steady @ 13.5 volts when several accessories including the A/C are active.
And +1 on the VR.
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 07-23-2010, 02:22 PM
Mitch Leland's Avatar
Voltage Drop...
Just to be sure what's going on have you checked to see if you have a voltage drop when you turn on the head lights, or the heater blower... By doing this you might determine if it's in the charging system or it's in the A/C system.
Mitch Leland
"03" 996 C2S-LS3 V8-480 HP
"84" 911 Turbo Look-Sold w/ found memories
Old 07-23-2010, 02:23 PM
All good ideas, will work at this problem. Thanks for the thoughtful responses. Lynn
Old 07-24-2010, 01:52 PM
