MFI Pump
How can you tell one pump from another? E,S 2.0, 2.2, 2.4????
Max Sluiter
Part number mainly. The space cam is all that is different. Except for the 1969 pumps with two solenoids.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Part number 90417514 with two solenoids.
so its a 1969 E or S |
Part number on the top of the like Max said. Picture below shows the Bosch ID tag. I have listed most of the pump parts number also below.
1969 2.0S 0 408 126 001 0 408 126 003 0 408 126 005 0 408 126 007 1969 2.0E 0 408 126 002 0 408 126 004 0 408 126 006 0 408 126 008 70/71 2.2S 0 408 126 009 0 408 126 011 70/71 2.2E 0 408 126 010 0 408 126 012 72/73 2.4S 0 408 126 013 0 408 126 021 72/73 2.4E 0 408 126 014 72/73 2.4E 0 408 126 015 73/74 2.7RS 0 408 126 019 ![]()
Mark Jung Bend, OR MFI Werks.com |
Just what I needed.
Thanks, Rob |
The number 90417514 is the serial number of the pump and should be a 1969 model. I can't tell if it's an E or S buy the serial number.
Max Sluiter
Yeah, I meant the ID tag. If you have the "005" you have a nice, late model 1969 911S pump with the most refined spacecam.
Max Sluiter
