gohan's Avatar
Connectors in question
Hi, I am working on swapping '80 sc engine into '73 and little confused on a couple of connectors. I appreciate it if anybody help me to identify them.
1. small two connector (white plastic with one red and one br/red wire) nearby the six CD plug and three vol reg connector. It seems something to do with speed limiter? Is it?
2. another one which has ye/bk and two br wires. My guess is it's for Heater Ventilator. Is it?
3. What is this sender for? It has bl/ye wire.
Thank you very much for your help in advance.
Old 12-31-2001, 09:18 AM
Wink
#2 looks like it goes to engine mounted blower, which should be elimated, IMO, and early heating system used. Do you have wireing diagram ??
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 12-31-2001, 02:03 PM
pjv911's Avatar
Send a message via AIM to pjv911
Thats the correct color code`s and plug end for the aux fan motor mounted on the motor. If you dont have the fan just tuck the wire away.
Never drive faster than your gaurdian angel can fly.
82 SC w/965S eng and G50 6:1 hp/w ratio
72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles
65/66 912 1 owner 76k orig
01' Aston Martin DB7 V12 Vantage Coupe 6spd
Old 12-31-2001, 04:22 PM
gohan's Avatar
Thanks RoninLB. I have already early heat exch. and muffler on, so I think #2 can be eliminated.
I looked at '77, '78, '80 sup. for ox sensor, '81 wiring diagram. I figured out 14 pin connector(and relocating few wires), vol regulator , six pin connector for emission control so on. However, I am not sure of these three items. Whether I use it or not, I'd like to know what they are. (I'd like to know what I'm doing as much as possible.)
Thank you for your help.
Old 12-31-2001, 04:39 PM
Cool
On picture #1 the br/red wire, the only thing I see in SC area of P-Workshop Manual is a br/red from B terminal on ign. coil to CD unit [6 pin] There is a br/bk wire from air flow sensor that is plugged into connector some where which turns to br/re before it goes to #85 of fuel pump relay.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 12-31-2001, 05:15 PM
On pic #3 an oil temp sender shows gr/bk in P- w man.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 12-31-2001, 05:28 PM
gohan's Avatar
The oil temp sender is located right next of the fun, close to the center of the engine. The oil temp sender is the same as '73; I can see them at the same location for the both engines. This #3 item is right side of engine???
Regards
Old 12-31-2001, 08:01 PM
