Valve Cover Gaskets....
I thought I would share my valve cover story in hopes of getting one of those Pelican Head concensus on what works the best.
I took on my first valve adjustment this past summer and a mechanic friend of mine was suggesting I bypass those "silcone beaded" valve cover gaskets for the OEM set and something he has had success with for years. I tried it and so far no leaks or problems.
I purchased the standard valve cover gasket kit and smeared wheel bearing grease on each side working it into the material. Yep! Wheel bearing grease. The gaskets were partially absorbed with the grease before I put them back on the head. I was advised that this will keep them from drying and that they will come right off as well as act as a moisture barrier. No extra torqueing of the hardware. I have to say that after so many thousands of miles, I have yet to see a drop of oil leak out.
What does everyone else use?
Regards and Happy New Year
Bob
73.5 T
Old 12-31-2001, 11:35 AM
tobluforu's Avatar
I went with the snake oil: "Silicone". Have them now for 2 years and 3 valve adjustments and no leaks since.
Old 12-31-2001, 11:58 AM
I can't imagine why smearing them with grease would get them oilier than what they'd absorb normally, but maybe that is a useful trick. I use the silicone gaskets after having had excellent service from them on a Lycoming aircraft engine.
Stephan
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 12-31-2001, 12:10 PM
mm86911's Avatar
Just did my first valve adjustment and used the stock material (no grease coat). No leaks after 100 miles. . .
Mike - PBG, FL
'14 958 Cayenne GTS
'05 997 C2 - SOLD
'79 911 SC Widebody PCA, NASA, PBOC - SOLD
2004 NASA-SE GTS4 Champ, 2005 + 2007 NASA-SE GTS3
Old 12-31-2001, 03:51 PM
MBAtarga's Avatar
Mike, Just curious, but how long did that first adjustment take. I'll be doing mine within the next month or so....
Mark
'83 SC Targa - since 5/5/2001
Old 12-31-2001, 08:33 PM
mm86911's Avatar
Knowing how detailed you are (same here) in cleaning up other parts while doing the job, plan on at least 2-3 hours. Gotta put the car on stands, clean up underneath, double check each valve, and a couple of beers afterwards. Drained the oil the night before so all was stone cold the next day. Changed the spark plugs afterwards - Bosch Platinums - then for a ride. No leaks and ran great.
Mike - PBG, FL
'14 958 Cayenne GTS
'05 997 C2 - SOLD
Old 12-31-2001, 08:51 PM
Senior Member
Leland Pate's Avatar
Ok, YOU two are GOING to HAVE to DO something ABOUT your PP handles.
We've got Mike and Mark...
You both live in Georgia...
You both have friggin' RED Targas!...
I'm going cross eyed here!
Chief Architect and Mastermind,
SCWDP
Old 01-01-2002, 07:42 AM
Senior Member
Zendalar's Avatar
Heres another red targa poster :P.
Well, the vaseline indeed keeps the gasket from drying out and therefore it won't loose its elasticity . I have used vaseline in carburator gaskets, but now that they work, I switched to gasket lacquer to be sure
//Zen, -72 Targa, red
Old 01-01-2002, 08:03 AM
mm86911's Avatar
Leland. . . it get worse. . .
We both starting the Pcar search in early 2001
We both looked at (and almost bought) another '83 Targa - hadn't even met each other yet!
We both made an offer on my '86. Mine was apparently higher as I ended up with the car.
AND. . . We live about 3 miles from each other.
Met each other on Pelican.
Mike - PBG, FL
'14 958 Cayenne GTS
'05 997 C2 - SOLD
Old 01-01-2002, 09:32 AM
JDaniel's Avatar
2-3 hours for your first adjustment? God you must be good. I lost track of the hours spent on my first adjustment
I think I could do it now in 2-3 hours...
Dan Tolley
1987 911 Coupe
The Owner's Gallery
2006 Audi A4 3.0q Cabriolet
2003 Ford F-150 XL Lumber and Trash Hauler.
Old 01-01-2002, 12:05 PM
Early_S_Man's Avatar
Porsche Crest
There seems to be some confusion about what gaskets are OEM and which aren't! The factory has gone through at least four different styles of gasket, and the latest style is what some call the 'green silicone bead' style. The 'silicone' gaskets that some have mentioned here are the Red, solid, 199% silicone gaskets from 'Real Gaskets' ... and they aren't OEM, but do seem to work well when installed at the very low specified 48 in-lb torque.
The factory spec books did not even have a torque specified for valve covers prior to 31 March 1981, when the '78-'81 SC spec book was published, and by that time the green-beaded gaskets were in use. The specified 6 lb-ft torque is less that what is used on the M6 studs for the sump drain plate nuts!!! I have never found it necessary to use a torque wrench on valve covers, but it would take a 1/4 inch drive model to be accurate at such a low torque level, and I do have one of those, a beam-style indicating torque wrench that works well for sump plates, chain covers, and rocker-arm shafts. Forget trying to use the same 3/8" drive torque wrench that you use on CV-joint bolts!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 01-01-2002, 12:38 PM
