-   -   Transmission Fluid Change / Where to jack it up to do so? (http://forums.pelicanparts.com/porsche-911-technical-forum/555770-transmission-fluid-change-where-jack-up-do-so.html)
smartbag 07-28-2010 04:16 PM
Hi...I need help cause I dont feel like bringin in my car to shop for $200 bucks to change the tranny fluid.
I bought a jack and stands and SWEPCO 201 fluid.
What i need to know is WHERE is the right place to jack up the car and HOW HIGH so i can get to the tranny to drain it and put the new stuff in?
Thanks so much for your help.
Photos would be helpful as well!
:confused:
RWebb 07-28-2010 04:39 PM
use 4 jack stands & keep it level; high enuff for you to get under & do it
test it by pushing to make sure it doesn't fall and crush you & put an elevated jack, wood blocks, spare tire etc. there for it to fall on just in case it does fall
Oh Haha 07-28-2010 04:41 PM
+1 AND be sure to loosen the FILL plug first. Use the correct tool(some are socket style and others are nut style).
smartbag 07-28-2010 04:47 PM
Great idea...thanks thats just what i needed to know. I guess I need 2 more jack stands!
HarryD 07-28-2010 09:19 PM
Follow my procedure here: Changing the Oil in an Early 911 Transmission
James Brown 07-28-2010 09:41 PM
Do you know how to jack it up to those jack stands??
