Smartbag Porsche 911 SC
Send a message via MSN to smartbag
Transmission Fluid Change / Where to jack it up to do so?
Hi...I need help cause I dont feel like bringin in my car to shop for $200 bucks to change the tranny fluid.
I bought a jack and stands and SWEPCO 201 fluid.
What i need to know is WHERE is the right place to jack up the car and HOW HIGH so i can get to the tranny to drain it and put the new stuff in?
Thanks so much for your help.
Photos would be helpful as well!
Old 07-28-2010, 04:16 PM
AutoBahned
RWebb's Avatar
use 4 jack stands & keep it level; high enuff for you to get under & do it
test it by pushing to make sure it doesn't fall and crush you & put an elevated jack, wood blocks, spare tire etc. there for it to fall on just in case it does fall
Old 07-28-2010, 04:39 PM
Oh Haha's Avatar
+1 AND be sure to loosen the FILL plug first. Use the correct tool(some are socket style and others are nut style).
Pacific Blue
Wayne
Old 07-28-2010, 04:41 PM
Great idea...thanks thats just what i needed to know. I guess I need 2 more jack stands!
Old 07-28-2010, 04:47 PM
HarryD's Avatar
Follow my procedure here: Changing the Oil in an Early 911 Transmission
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 07-28-2010, 09:19 PM
Senior Advisor
James Brown's Avatar
Do you know how to jack it up to those jack stands??
08 Cayenne Turbo
Old 07-28-2010, 09:41 PM
