-   -   Best/safest way to disable ignition on 3.2 (http://forums.pelicanparts.com/porsche-911-technical-forum/556150-best-safest-way-disable-ignition-3-2-a.html)
dtw 07-30-2010 06:45 PM
Going to do a CR test on a 3.2 tomorrow - what is the best way to disable the ignition so I can safely turn the motor on the starter, with all the plugs out? Thanks!
Flat6pac 07-30-2010 07:14 PM
I like to pull the wire from the coil and unplug the injector harness off the left front of the engine located on the chassis.
Bruce
dentist90 07-30-2010 08:14 PM
I believe if you unplug the DME relay (under driver's seat) you will not only disable ignition but the fuel pump as well.
Steve@Rennsport 07-30-2010 08:21 PM
That right and the best way to do it,....:)
dtw 07-30-2010 10:17 PM
I knew y'all were going to say DME relay. Thanks gents!
