GAFB
Best/safest way to disable ignition on 3.2
Going to do a CR test on a 3.2 tomorrow - what is the best way to disable the ignition so I can safely turn the motor on the starter, with all the plugs out? Thanks!
Several BMWs |
I like to pull the wire from the coil and unplug the injector harness off the left front of the engine located on the chassis.
Bruce |
Immature Member
I believe if you unplug the DME relay (under driver's seat) you will not only disable ignition but the fuel pump as well.
1984 Carrera Coupe = love affair 1997 Eagle Talon Tsi = old girlfriend (RIP) 2014 Chrysler 300 AWD Hemi = family car "Lowering the bar with every post!" |
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
GAFB
I knew y'all were going to say DME relay. Thanks gents!
