Justin@Athens's Avatar
Send a message via AIM to Justin@Athens
Battery drain eliminated, rust issue ensues.
Ok, so I found my parasitic battery drain. It turned out to be an unfused lead from the positive battery terminal to the power windows.
During the course of removing the battery I found a nasty rust issue where my negative battery post grounds to the car.
The upper left hole is where I just cut the current post out. But it appears this repair may have already been done once before as you can see from the larger vacant hole below it.
How should I go about fixing this, and where is the optimal place to ground my battery now?
1990 964 C4 Coupe & 1991 964 C2 Coupe (current)
1989 911 Targa (sold)
1996 993 Cab. (sold)
1999 x2 Boxster (sold)
2006 Cayman S (my daily)
Old 08-06-2010, 04:31 PM
