Options for externally adj shocks on a SWB??
I have a 67S that I'm starting to autox a bit. In planning my suspension changes I'm starting to wonder if there are any shocks/struts available that are externally adjustable, like the Koni sports with the dial on top.
Right now I have Koni reds but's it's a major pain to adjust them, that and they only have rebound adj anyway. I've read that Paragon has a modified Koni sport shock for the rear that will work on 69-73, but not SWB.
Thanks!
Current: 1975 911S --Chocolate brown
Past:
1967 911S --Bahama Yellow
1990 C2 Targa --Silver
1973 914 2.0 --Delphi Green
Old 08-08-2010, 12:12 PM
Mark S
Yes, contact Paragon I run Koni 'sports' on my 67. You will need a $15 set of adapter bushings @ the rear. I cut dust covers a bit so I could adjust W/O removing rears, you have to push a detent ball under the dust cover to adjust @ least on the ones I have but you don't have to bottom piston to adjust. To adjust rears on mine it does take two people, one to depress detent ball one to turn adjuster @ top. At front one man job with knob. If you need pic's of dust cover mod or want more info PM me.
Just dawned on me I'm running later model front struts, call Paragon.
Old 08-08-2010, 08:23 PM
