Tachometer stops working!
Hi,
I have a problem with tachometer which stops working after around 8-10 minutes of driving. When fired again with engine cold it starts to work again. The car is stock 911 2.2 T . What should I check? Tachometer connections or distributor? Something else? Thank you Marcin
1976 3.0 Carrera sold ![]() 1975 2.7 backdated to 73' RS 1971 2.2 T Targa |
Hve you checked your points and condensor?
Ed 1973.5 T |
tachometer
No I have not. I presumed they are ok since tacho starts to work and stops after a couple of minutes.
