porsche question
hi. guys i have a question my 1979 porsche 911 is making a clicking sound in the rear on the drivers side. im thinking its the cv joints do anyone knows how i can inspect it. are what to check for i know a little mechanic i never done cv joints thanks for your time.
sylvester
Old 08-09-2010, 03:18 PM
CV sounds likely, unbolt the CV, clean and check for wear. Have a couple of spare bolts handy.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 08-09-2010, 04:49 PM
crustychief's Avatar
If you look under there and see the boot is torn, you can just about be sure the joint is toast. There are a lot of Pelicans in Houston, someone might donate an experienced eyeball.
A nose heavy airplane flies poorly, a tail heavy plane flies once.
Old 08-09-2010, 05:01 PM
Originally Posted by sylvester View Post
hdo anyone knows how i can inspect it. are what to check for
Grab the axle firmly next to the CV joint and yank it back and forth and up and down. Any movement in the axle - at either end - the joint that end is toast, no question.
You sometimes find no play if the wheels are off the ground, and play when they are (different area of the bearing in use) might want to check both ways. Most wear will occur in the normal position - i.e. with the wheels on the ground, fully-loaded.
My advice? Replace the axles complete unless you enjoy having moly grease up to your elbows for hours on end... If one is toast, odds are high the others are not far behind.
Many good threads on the correct fixing methods for the axles here, be careful removing the bolts or it can get unpleasant. There's even some snazzy new locking bolts.
'77 S with '78 930 power and a few other things.
Old 08-09-2010, 05:25 PM
porsche question
ok. thanks for all replys
sylvester
Old 08-11-2010, 02:47 PM
