Harness mount - is this right?
I had my cage, driver seat and harness installed by a reputed racing shop in Long Island NY. They installed the inside part of the harness with an eye bolt to the wall of the tunnel, instead of installing it to the floor. There is only a regular washer on the inside of the tunnel, since the eye bolt is close to the floor so it won't allow for a backing plate/washer.
I am ready to install the passenger side seat and harness and wanted to make sure that this mounting point is appropriate. The outside mounting point is on the factory seat belt mounting with an eye bolt
Mario '76 911 w/'97 3.6 Euro Vario Engine & Turbo body kit & TPC Supercharger '15 GT3 |
Not sure what we are looking at in the photo....
Your lap belts can be mounted with eye bolts threaded into the factory seat belt mounts. Your shoulder harness should be wrapped around your cage directly behind your seat to minimize stretch. Your sub belts can be mounted to to eye bolts threaded through the floor under the seat to BIG backing plates or to a custom fabbed or readily available sub mount bar.
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
The lap mounting points are both where the original seat belts were mounted, I assume that is what is under your rug? If so that is correct. For mounting the anti-sub straps for your 5-6 point you need to drill holes and use backing plates under the car and shoulder belts attach to the harness or harness bar with the angles set properly according to the mfg.
Gary R. |
the picture is looking at the tunnel.
No, the eyebolt is not on the factory mounting point. They drilled a new hole on the wall of the tunnel and installed the eyebolt there with a regular washer and a nut on the inside of the tunnel. I will try to installed it on the stock mount. thanks
the tunnel lap mount is usually a reinforced eye bolt throught the tunnel wall on a 964 up car, the tunnel walls are immensely strong
here is where the later cars have harness mounts ![]() on an earlier car it's probably a good place for the mount too, it least as good as throught the floor anyway
On my SC's I simply unbolted the sealt belt mounts and screwed in the eye bolts from the kit, no need to drill anything for the lap bolts. I'm surprised that all 911's at least through the 90's didn't have the same mounting points?
Gary R. |
1997 Boxster 2.5L 1975 911S Project |
Gary R. |
