Tim Boyer's Avatar
cam question
Hi,
Can you use a cam from a '69 T in a '70 E motor (assuming that it is ground to the proper specs)? One step further, can this same cam be ground to S specs?
Thanks for the input.
Tim
Old 08-11-2010, 01:39 PM
Under the radar
Trackrash's Avatar
Yes.
Yes.
Gordon
'71 911 Coupe 3,0L outlawed
Old 08-11-2010, 01:48 PM
mcaterino's Avatar
Tim,
This isn't something I know a tremendous amount about, but I think it's only a 'maybe'. I was going to have my 70 T cams ground to E specs, and John Dougherty ('camgrinder') said is was only possible if the T cams were in pristine shape. Mine were too worn to take to an E profile. Don't know about S, but perhaps the same applies.
Mike
Michael Caterino
Clemson, SC
1970 tangerine (=Tiger Orange) 'T' targa
restoration: mk911.blogspot.com
Old 08-11-2010, 01:53 PM
tobluforu's Avatar
Don't T cams have to be welded in oder to make them into e or s cams, then ground? Then you have the pistons to deal with.
But if you are asking can you take a T cam and put it into an e engine, then yes.
Old 08-11-2010, 02:13 PM
Fleabit peanut monkey
Bob Kontak's Avatar
I agree with the welding - how do you add lift and duration to a short skinny lobe without adding metal?
Old 08-11-2010, 05:37 PM
