-   -   Help identifying a part (http://forums.pelicanparts.com/porsche-911-technical-forum/558343-help-identifying-part.html)
Forza 08-11-2010 02:48 PM
First off, I know a picture is worth a 1,000 words, but I'll try to describe what I'm looking for in far less....
My '83 SC is supposed to have two L-shaped black plastic seals or covers (one for each door) that either rivet or screw into place where the front of the window frame meets the door (See #25 in figure below for approximate placement).
http://forums.pelicanparts.com/uploa...1281562894.jpg
My driver's side seal is deteriorated, so after being removed, there is a small gap between the front of the window frame and the door itself (where the window frame fits down into the door itself). I'd like to insert a new L-shaped seal to keep water out, but can't find the part anywhere on Pelican. Anybody know what this part is and its part number?
RWebb 08-11-2010 03:01 PM
is this a small part - the size of a fingernail??
if so, then a search on wind + noise will turn up some info in case nobody knows what it is right off
Oh Haha 08-11-2010 03:05 PM
I thinkk this is what you want- 911-555-421(L)+422(R)-00-01C-OEM
I got this from the Pelican catalog.
Forza 08-11-2010 04:05 PM
Good guess given the info I provided, but that is an interior trim piece. The part I'm looking for mounts on the window frame itself in the A-pillar section to provide a seal between the window frame and the top of the door itself.
I'll see if I can snap a pic of my intact passenger side one to clarify things.
Forza 08-11-2010 04:13 PM
http://forums.pelicanparts.com/uploa...1281568400.jpg
Poor-sche Lover 08-11-2010 04:26 PM
Maybe this? 911-531-711-02-01C
Oh Haha 08-11-2010 04:39 PM
Yes, that's it!!!
Nice job Poorschelover. Thanks for the assist.SmileWavy
Forza 08-11-2010 05:42 PM
Yes, that's it--thanks!
