Stibbich 6:11.13
First off, I know a picture is worth a 1,000 words, but I'll try to describe what I'm looking for in far less....
My '83 SC is supposed to have two L-shaped black plastic seals or covers (one for each door) that either rivet or screw into place where the front of the window frame meets the door (See #25 in figure below for approximate placement). ![]() My driver's side seal is deteriorated, so after being removed, there is a small gap between the front of the window frame and the door itself (where the window frame fits down into the door itself). I'd like to insert a new L-shaped seal to keep water out, but can't find the part anywhere on Pelican. Anybody know what this part is and its part number?
Cheers! John B. Ellis 1983 911SC Coupe 1996 Jeep Cherokee Sport Last edited by Forza; 08-11-2010 at 04:09 PM.. |
AutoBahned
is this a small part - the size of a fingernail??
if so, then a search on wind + noise will turn up some info in case nobody knows what it is right off |
I thinkk this is what you want- 911-555-421(L)+422(R)-00-01C-OEM
I got this from the Pelican catalog.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
Stibbich 6:11.13
Good guess given the info I provided, but that is an interior trim piece. The part I'm looking for mounts on the window frame itself in the A-pillar section to provide a seal between the window frame and the top of the door itself.
I'll see if I can snap a pic of my intact passenger side one to clarify things.
Cheers! John B. Ellis 1983 911SC Coupe 1996 Jeep Cherokee Sport |
Stibbich 6:11.13
Maybe this? 911-531-711-02-01C
Alan Past: '74 914 2.0, '82 911 SC Targa, '88 911 Cabriolet, '88 911 Cabriolet again Present: '00 Boxster S "Happiness is not around the next corner......happiness IS the next corner." |
Yes, that's it!!!
Nice job Poorschelover. Thanks for the assist.
Stibbich 6:11.13
Yes, that's it--thanks!
