Hi
brake boost vacuum hose
Hello Everyone,
![]() Can anyone tell me what size (I.D.) and length is the vacuum hose for the brake booster on a 84 Carrera. Thanks in advance.
"A good sense of humor is the best thing to have in your toolbox when working on these cars." Quote by Charles Freeborn, Pelican. |
Schleprock
At what location do you need to replace it? It's not all one piece from the booster all the way back to the engine.
The parts diagrams say it's 12mm OD and 4mm ID. 4mm seems rather small to me, based on memory. But the hose has to be thick enough to prevent collapse due to suction. So 4mm would make sense even though I don't recall fittings that small connecting to the hoses
Kevin L '86 Carrera "Larry" |
Hi
This is the hose that is in the engine bay next to the cruise control. the hose runs from there, through the firewall and connects underneath the engine where the tunnel begins. 4mm seems small, i would have guessed 12mm i.d.
ID 12mm or 15/32" for sure, use only fuel hose with textil inlay
Roland 930 Turbo '81 Too many modifications to list |
Schleprock
Must have misread the parts diagram. It shows 11,8 x 4 for that hose. 4 must be the hose wall thickness.
Somatic Negative Optimist
12 mm I.D. sounds about right.
It can be bought by the foot off a roll; 1/2" will work. Look at the existing hose and follow it undrneath the engine to the tunnel. Estimate the length and add a foot to be sure. You MUST specify that it is for vacuum; fuel hoses are different. Vacuum hose is designed to prevent collapse. Fuel hose is designed for pressure and to resist deterioration from gasoline.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Senior Member
Smart fix - a leaking hose here has all sorts of bad implications. A simple test for our vaccum-assisted cars: Car off, pump brake pedal three times, apply easy, slight pressure to brake pedal and start car. If you feel the pedal pull in, away from your foot chances are the vaccum is still good.
Let me know how this goes - a solid piece of maintainence for sure!
'78 Targa in Minerva Blue |
