-   -   Random O-ring in shift linkage? (http://forums.pelicanparts.com/porsche-911-technical-forum/558624-random-o-ring-shift-linkage.html)
Arkman 08-13-2010 06:09 AM
knowing that nothing is random in a Porsche engineers mind - can someone tell me what the o-ring on the shift linkage is for on an '87 G-50?
Sorry, no pic - I noticed it when replacing the boot that goes from the cabin to the transmission. There seems to be a boot AND an O-ring. I did look at the parts catalog but cant find a diagram of the linkage - just a parts list.
Thanks!
Chuck.H 08-13-2010 06:37 AM
There is a Porsche TSB that describes using an O-ring or rubber band to stop some rattling in the shift linkage under that rear-seat floor tunnel, perhaps that's what you're seeing? Maybe it came loose from where it was...
HTH,
Chuck.H
'89 TurboLookTarga, 320k miles
KTL 08-13-2010 06:47 AM
Chuck is correct. Strange fix that only works for a little while until the o-ring permanently stretches.
http://forums.pelicanparts.com/uploa...1281707252.jpg
88911coupe 08-13-2010 10:24 AM
My oring looks fine but seems way too loose to put any sort of pressure. I wish the pic was not so poor.
