3.2 fan with 964 housing
Is it possible to use 964 fan housing 964 106 667 02 with -87 engine? I would like to use 84-89 fan/impeller and alternator on new housing as it's difficult to find good 3.2 housing. 964 fan is not as efficient as older with straight cut blades so trying to keep old fan. But not sure if 964 housing is deeper than 3.2. Do you know?
Samu
911 -87 Marine Blue, 3.5 twin plugged, DC24, 22/23 sways, 22/29 bars, PB front and rear, G50 with Cup LSD, Heigo CS cage
911 -73 track project
Old 09-24-2010, 05:14 AM
PRO Motorsports
Tyson Schmidt's Avatar
It won't work.
The 964 housing doesn't fit you engine, and the fans are not interchangeable.
There is a straight blade fan for the late set-ups . The 964 Turbo had a straight blade fan and uses the 964 style housing and alternator.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 09-24-2010, 01:03 PM
