-   -   7R case question (http://forums.pelicanparts.com/porsche-911-technical-forum/559052-7r-case-question.html)
Shoepop 08-15-2010 08:40 PM
7R case question
I just received my copy of Wayne's how to rebuild and modify book he states the 73.5 CIS motor is the earliest 7R case with spigot spacing for 2-2.4 cylinders. I have a 73 2.4 E MFI engine with 7R case book lists engine # as out of 73 with Sporto one of those transition things?
regency 08-16-2010 06:00 AM
Shoepop, Do you have a Red Book to check your engine & trans #'s? Have you owned the car since new?
73 911 T, Coupe MFI Aubergine
BK911 08-16-2010 06:58 AM
Later 73Es and Ss could have a 7R case.
Shoepop 08-16-2010 07:41 AM
Yes Steve I checked the #'s both type and serial. I don't own the car just picked up the engine no trany because it was cheap clean and complete.
regency 08-16-2010 07:54 AM
Is the engine complete? Lots of good stuff, the MFI system alone is pretty valuable.
Shoepop 08-16-2010 08:31 AM
Yes it's 100% complete with the exception of missing flapper box, even got the electrical console with it.
356RS 08-16-2010 10:36 AM
Shoepop, check both sides of your engine case for the casting numbers. I have a 73 T with MFI and the case type number is 911/51 but the case half's show 102.7R on the right and 101.5R on the left. This engine has never been rebuilt.
Shoepop 08-16-2010 11:59 AM
Mark, I just checked left side 901-101-101 7R, right 901-101-102 7R, engine type sporto 911/62, engine # 6239200.
fryardds 08-16-2010 02:09 PM
Also the later '73 Carreras have 7R cases. A few of them even have Alumiunm 7R cases but that is another story.:)
