-   -   Trying to identify a non-matching engine serial # (http://forums.pelicanparts.com/porsche-911-technical-forum/559541-trying-identify-non-matching-engine-serial.html)
Drumboxer 08-18-2010 12:28 PM
I am looking at buying an older 911, and the motor is not original. I am posting to see if anyone can help me with what engine it might be that is in the car.
Serial # is: 6670691
Any help would be great, Thanks!
Shoepop 08-18-2010 01:07 PM
The # indicates it is a 1977 3 liter carrera engine. If you can check type it should be 930/02
356RS 08-18-2010 01:07 PM
That number comes back as a 1977 3.0L engine.
djpateman 08-18-2010 01:09 PM
That should be a 911 Carrera 3,0 type 911/48 engine
Drumboxer 08-18-2010 01:46 PM
Thanks for the help!
Bob Kontak 08-18-2010 01:53 PM
IS this the engine w/210 hp?
Grady Clay 08-18-2010 02:07 PM
*6670691*
6 = Unit type 6-cylinder engine,
6 = Engine type 1977 models; Carrera, 3.0L, 200 hp, type 930/02.
7 = Model year 1977.
0691 = Consecutive serial number.
Total 1932 built.
95x70.4 mm = 2994 cc.
K-Jetronic (CIS) fuel injection.
200 hp @ 6000 rpm, 188 ft-lbs @ 4200 rpm.
Best,
Grady
awdbandito 08-18-2010 02:14 PM
Get it. I owned a 77 carrera and it was a phenomenal car. I wish I hadn't sold it for a 3.2
The 3.0 carrera engine didn't feel good until 4k RPM but man if you kept it spun up it was a blast to drive.
If it is in an older light weight car you will always have your foot in the gas and a huge smile on your face.
tonythetarga 08-19-2010 06:05 AM
I am looking at buying an older 911, and the motor is not original. Serial # is: 6670691
What leads you to believe that this is not a numbers matching car? Do you have a COA or are you expecting to see identical numbers on the engine and VIN? (because that will never happen)
Drumboxer 08-19-2010 06:16 AM
The car is a '75 US-Spec 'S', it's non-matching in a good way. Now it's just a matter of getting a fair price. Thanks again.
trak ratt 08-19-2010 06:19 AM
No, ~180 and CIS like the later SCs. The 210hp motors were 2.7 w/MFI and I think gone by '75.
Shoepop 08-19-2010 07:37 AM
[QUOTE=Bob Kontak;5513493]IS this the engine w/210 hp?[/QUOTE
No, it's EXACTLY as Grady's post spelled it out.
951highboy 03-27-2015 10:12 PM
non-matching numbers engine
Hello...curious if you are referring to a yellow '75 911 that was up for sale in Cincinnati, Ohio via ebay about 5 or so years ago? If so, I bought that car and it is sitting my garage awaiting restoration. The engine serial number is 6670691 and from quick research I did, I came up with the following:
1977 Euro
bore - 95mm
stroke - 70.4mm
hp - 200hp (DIN), 197 (SAE) @ 6,000 RPM
Max RPM - 7,000 (redline)
The car is a fairly straight non-sunroof coupe 911S with only a little rust in the frt fenders. The car has changed owners four times and has had three color changes, but no accidents. I noticed the 3.0 liter motor when it was advertised and just happened to be in the area...long story short, I made a quick trip down to see the car and pulled the numbers off the engine, researched them that night and bought the car with the intention of building a euro spec Carrera 3.0 clone.
-T
quattrorunner 03-28-2015 12:07 AM
Nice
billybek 03-28-2015 05:31 AM
Cool!
Would be nice to see some photos of the restoration/modifications as you move along.
Congrats,
JT912 03-28-2015 07:55 AM
So what is really going on here?
biopsea 03-28-2015 08:15 AM
Yes, I am confused as well JT912
biopsea 03-28-2015 08:16 AM
Gonna throw this out to the world. The engine that came in my car originally is 6670430. Are you out there?
quattrorunner 03-28-2015 08:21 AM
I think the original poster sold. Now 5 yeas layer someone found this thread googling his engine number.
