Unsafe at any speed
Nader's Avatar
Question Windshield wiper problem
When I switch off my wipers, they don't return to the starting position. Also, the intermittent function doesn't work. Where should I be looking for a bad connection? Thanks in advance.
87 Carrera Coupe
Old 01-05-2002, 10:02 PM
critter's Avatar
I would ask J Walker as he is in your neck of the woods but if it was my car I would probably be changing the wiper motor from my past experience with the same problem.
Grant 75 911s targa
1991 Dodge Cummins turbo diesel 3/4 ton 4x4 ( stump puller)
Old 01-05-2002, 11:10 PM
cary's Avatar
Ditto on the Mr. Walker help .......... He helped me thru the same thing. Mine was the wiper switch and a bad connection on the wiper motor. Connections right behind the clock.
Do a search. Should be lots of ideas.
Good Luck
Cary
77 Carrera RS w/3.2 #59
73 914S 2.0 AG
73 914 1.7 Driver ( daily driver, under complete rustoration )
74 914 2.0, 71 914 Tub, 74 914 2.0 Tub + 73 914 donor
Old 01-06-2002, 05:52 AM
Senior Member
Leland Pate's Avatar
I've never told anybody this but...
...If I plug a CB radio into my cigarette lighter and key the mike...my windshield wipers will start going back and forth until i let go of the mike.
I H A V E N O I D E A .
Chief Architect and Mastermind,
SCWDP
Old 01-06-2002, 06:51 AM
michaelw's Avatar
Nader:
The exact same thing just happened to the wipers on my 87 Targa. Help?
Michael
Old 01-06-2002, 07:59 AM
Senior Member
Hello
Just check if your wiperswitch is working correct. There is a bridge/wire to run back the wiper to the park position.
Grüsse
Old 01-07-2002, 12:34 AM
