Banned
Send a message via AIM to prebordao Send a message via Yahoo to prebordao Send a message via Skype™ to prebordao
What should happen when removing oil cap ?
I remember reading sometime ago that when you remove the oil cap, while idling, that revs should drop.
Well mine doesn't... what does it mean ? a vacuum leak somewhere ??
Old 08-19-2010, 12:18 PM
Oh Haha's Avatar
RPMs should drop a few hundred or so.
Yes, a vacuum leak is typically the source if they don't drop.
Pacific Blue
Wayne
Old 08-19-2010, 12:43 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Correct. I read this test in a lot of posts where folks are having CIS running issues. If it does not drop the rpm, you may have a real big leak - which can be easier than a real little one(s) to find.
I did see a post from John Walker's Workshop about the brake booster hose cracked under the car - by the transmission - that would be impossible to find from the engine bay.
I found one of my injectors popped out of the intake runner once. I have taken off the CIS and the fuel lines were a little bent so I straightened them on re-install but left too much stress in the #6 line - pop goes the weasel.
Also check if your air bypass adjustment screw is all the way in you definitely have a vacuum leak.
Old 08-19-2010, 12:48 PM
arbita1's Avatar
If you can't find any major air leaks, then check your CO setting.
I had this problem and couldn't find any severe air leaks. I did find that my CO was set extremely rich. Once I brought it into spec, the RPM's would drop with the cap off.
Matt.
83 911SC
85.5 944 NA - Sold
Old 08-19-2010, 01:28 PM
Jupiter 911
bklyn's Avatar
Would this also apply to an 87 3.2? Because my also does not make any difference with the cap on or off.
Lenny-1987 3.2 Targa Guards Red/SW Chip
Fabspeed Exhaust/Cat bypass
MSDS Inc. intake/Clewetts
Euro pistons and cylinders.
2002 Boxster Artic Silver/Wifes ride.
Old 08-19-2010, 04:05 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Exclamation For Sure...
Yeah mine 86 3.2 does drop a few hundred of RPM. You should hear it when you take the cap off... and will rev up a bit when you put the cap on.
Good Luck
Who Will Live... Will See
Old 08-19-2010, 04:22 PM
Jupiter 911
bklyn's Avatar
Well I guess I am going out to the garage, maybe I just cant hear it because it runs great.
Old 08-19-2010, 04:25 PM
Wyvern's Avatar
Depends on the year vehicle ..
My 75 has the breather routed before metered air ... doesn't make any difference with cap on or off.
Your sig says "74 911" so you may be like mine
Brian
Old 08-19-2010, 05:28 PM
JJ 911SC's Avatar
Arrow Unless you are rich...
Don't waste money... If it working fine leave it alone and just do the usual air leak fault finding by spraying carburetor cleaner around the hoses.
P.S. If you are Pitch Deaf Tone... Check the RPM before you take the cap off and check the gauge after you take the cap off.
Good luck
Old 08-19-2010, 06:02 PM
Banned
On my 74 there are 2 breather hoses coming from the oil tank. one goes to the airbox right behind the filter (so before metered air), the other goes to somewhere behind the throttle body, I can't really pinpoint where, but it should be after metered air.
Old 08-20-2010, 01:43 AM
The system wasnt closed to affect the idle until 78 model year.
Bruce
Old 08-20-2010, 05:00 AM
dshepp806's Avatar
hoses' oil restrictor missing?
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 08-21-2010, 02:34 PM
Bob Kontak's Avatar
Looked at the parts diagram - no restrictor before '78. Bruce is correct.
Old 08-26-2010, 11:06 AM
Canucks Fan
should it do the same on a 930?
Old 08-26-2010, 12:03 PM
Bob Kontak's Avatar
S_Morrison57 - Link below shows you how to get to the parts diagrams - This may be old news to you.
However, the oil systems look identical in the 911 and 930 through 77 and they look identical from 78 on in both as well. But it changed in 78. Pre78 you have to look at two sets of diagrams. 78 forward they are merged.
The restrictor valve came to play in 1981 - probably in response to the idle dropping too low with the newer system. This info is just from looking at the diagrams - I can't explain the real reason for the closed system as Bruce describes it. I looked at my RoW diagrams and they are pretty much the same as the US ones.
FWIW - I have a friend with an 89 930 and I know the idle drops in his with the cap pulled.
Old 08-26-2010, 02:26 PM
