BBS Technical Help
How do I do a couple things on the board?
1. How do I attached an image under my name that appears at the left of each posting? 2. How do you guys post images with your posts and reply's? I have a limit of 65k, and I am sure many I have seen are larger (or are they?)
Vance '83 SC Cabriolet - The "Matrix" '73 914 - "Spicy Mustard" - SOLD |
I'm 99% computer illiterate, but if you click on the f.a.q. icon, I think you'll find answers to your question.
vesnyder,
If you make your pictures jpeg's, the file size will be much less than that of a bitmap for example. Also, if you resize your image to 72 DPI (thats the best possible resolution you can view on a standard screen) the file shall reduce in size. Hope this helps.
Chris - - - - - - - - - - - - - - - - - - - - - 1982 911 SC Hellblau Metalic - - - - - - - - - - - - - - - - - - - - - 1997 Boxster 986 2.5l |
