pjv911's Avatar
Send a message via AIM to pjv911
check this engine out
http://cgi.ebay.com/ebaymotors/aw-cgi/eBayISAPI.dll?ViewItem&item=600117916&indexURL=2#ebayphotohosting
Never drive faster than your gaurdian angel can fly.
82 SC w/965S eng and G50 6:1 hp/w ratio
72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles
65/66 912 1 owner 76k orig
01' Aston Martin DB7 V12 Vantage Coupe 6spd
Old 01-06-2002, 07:35 PM
Thanks. But no thanks.
Old 01-06-2002, 08:11 PM
A 4 barrel? Looks weird.
Bill
William Armentrout
1973 911T
2.7 carerra rs specs
Old 01-07-2002, 05:04 AM
rob911's Avatar
Bill
Why a 4 barrell, shurely six plug leads and inlet tracts?
Did anyone wonder why two different inlet systems are shown, are they in fact the same engine.
01 Maserati 3200 GT Assetto Corsa
84 3.2 cabrio - gleaming
99 Alfa Romeo 166 3.0 V6 super - still going
03 Fiat Punto 1.2
http://www.pelicanparts.com/gallery/rob911
Old 01-07-2002, 05:31 AM
Friend of Warren
Originally posted by rob911
Bill
No reason a 4-barrel wouldn't work, they work just fine on V-8's. As for the two carb/intake systems, the seller says he is selling both with the engine. Actually it is an interesting concept. Did anyone also notice that he appears to have swapped a GM electronic ignition distributor for the stock 911 dist.?
Kurt V
Old 01-07-2002, 06:23 AM
I also noticed the GM HEI distributor with the cap mounted coil...not bad, if you're tired of CDI.
Might make a good tech article on how he was able to adapt it.
Joe Garcia
Old 01-07-2002, 08:51 AM
