Ignition switch question
When I start my car, the key does not return to the run position and the starter remains engaged on the flywheel. I can manually move the key from the start to run position and this corrects the problem. My question is, where is the spring mechanism located? Can I change the electrical part on the back of steering lock or does the entire assembly need to be replaced?
www.exeterautosupply.com
1976 911S Targa
Old 08-23-2010, 08:26 AM
The spring mechanism is in the switch.
This switch is attached with 2 screws at the back of the steering lock assembly.
Old 08-23-2010, 08:43 AM
Yes the electrical side of the switch can be replaced separately from the mechanical steering lock.
Edit: Holy cow, those are some cool Offys!!! I should take a drive down to Exeter to take a gander.
Old 08-23-2010, 10:58 AM
Thanks for the help. Come on down!
1976 911S Targa
Old 08-23-2010, 04:07 PM
I will. I see you are open until noon on Saturdays!
Old 08-23-2010, 04:10 PM
