Mytherapy911
Help 911 not starting !!
My 911 will not start .. The car cranks over no problem .Checked and has spark from coil , tried taking off the air filter and spraying starting fluid directly in and still not starting .. can anyone help with this problem ..It's a 1990 911 Cabriolet . Not a Turbo.. Thanks
Old 04-14-2011, 03:26 PM
Capitalist and Patriot
911Freak's Avatar
lots and lots of threads on this, even a tech article I think.
Air-Fuel-Spark
fuel pump operational? pump pressure?
do not use started fluid!!! these aren't Briggs and stratton lawnmower engines!
please, put down the starter fluid
Check for proper fuel pressure and report back (also do a search for "no start" etc. You'll find excellent checklists to work off of
Good Luck
Former Test driver & Production Manager Singer Vehicle Design
2009 Cayenne GTS, '81 911SC RoW Targa (lot's of goodies), '86 535csi, '84 633 csi (turbo charged-sold) , '68 912 Targa (sold) , '69 911E (sold)
"Dream it, Believe it, Decide it, DO it "
Old 04-14-2011, 03:35 PM
Mytherapy911
Help
Thank you for your advice will check that next . Starting fluild just hit the garbage.
Old 04-14-2011, 03:39 PM
Fleabit peanut monkey
Bob Kontak's Avatar
If you use the search function choose the advanced search option. Then type in some text like "fuel flow" and isolate the search to the 964 board.
Here's one I found saying the DME relay can be a culprit.
Motor spins, won't fire
Old 04-14-2011, 03:41 PM
Drisump's Avatar
If the set up is similar to a 3.2, a malfunctioning DME relay does present itself with that symptom. (It will not turn turn the fuel pump on) Assuming other similarities (to the 3.2), other possible problems are a few sensors that are found around the engine supplying info to the DME. One of which is the one that will not allow the pump to function if the engine isn't rotating at a set rpm (ie. cranking speed). Cheers
Old 04-15-2011, 06:53 AM
