964 Cams, How much torque on the Cam Bolt?
I'm installing 964 cams on my 911. I can't seem to find a torque value for the cam bolts. Does anyone know?
It is 89 lbs/ft for the SC and 3.2. If you use the same bolt and "washer" as they do, it should be the same for the 964s, but I'd be inclined to find a 964 manual to confirm that.
Fleabit peanut monkey
You are correct, Sir.
120 nm (88.5 ft lbs) in the little SC tech book for the bolt. 150nm (110ft lbs) for the nut. |
Thanks guys!
