1985 Carrera vs. 1986 Carrera
Hi, my understanding is that the 1985 Carrera and the 1986 Carrera are "virtually identical". However, I wonder if there are in fact any differences. Did Porsche introduce any innovations for the Carrera for the 1986 model year?
M491 Coupe Owner
The '86 Carrera has bigger A/C vents, larger anti roll (sway bars), larger rear torsion bars, the seats were 20mm lower, and the trunk carpet was upgraded.
Silver '86 Turbo Look Coupe |
Formerly known as Syzygy
I believe the 85 also has a different evaporator box for the AC in which you can use Kuehl's fan, where the 86's is different. That's all I got...
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. |
Late 86's came with the 87 control units.
86 was first year for 3rd brake light
Kevin '87 Targa |
Recreational User
Late 86 also got the fuses for the footwell blowers, and the cruise control module was moved from the trunk to under the radio.
The 85's are also the only year to have about 3/4 inch more height on seat mounts. Good if you're a shorter fella but not so good if you are 6' or above.
Currently Without Porsche 1981 931GT (SOLD) 1985 911 Carrera Targa (SOLD) |
My '86 was built in February, no footwell blower fuses but the cruise module is under the radio.
1986 Carrera Coupe 1999 Chevy Tahoe 1987 Chevy Blazer 1955 Chevy Apache 3100 Pickup "A little knowledge is a dangerous thing" |
Most '85's had the demountable rear axle shafts at both ends ( bolted both ends), whereas I believe later models had outboard ends friction welded...... others here can chime in with details on this....
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Thanks all -- very helpful and interesting.
Mo money = mo parts
Correct. Porsche changed the axle shafts mid-way during the '85 production run, so depending on the date of manufacture for the '85 it will either have the earlier (75 - 85) outer cv that can be detached from the hub or the later (85 - 89) outer cv that is integrated with the hub. The only impact is you need to replace the entire axle if the outer cv's go bad.
Greg 86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten 65 Ducati Monza 250 & 66 Monza Junior (project) "if you are lucky enough to own a Porsche, you are lucky enough" |
Recreational User
Yep, February build was too early for the fuses. My car was built in June '86 and it has the fuses from the factory.
