opie's Avatar
1986 911 condenser fan
My 86 condenser fan went out and was wondering if someone could tell me if its ok to drive about 10 hours without it. I unplugged the plug going to the harness just wanted to make sue it doesn't control anything else. Thanks.
Old 04-22-2016, 01:01 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Not a good ides, as the system pressure may exceed
the system specifications.
If you don't one of these-
Please install one of these.
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 04-22-2016, 01:38 PM
opie's Avatar
So even if I don't use the ac I will still need the fan. I'm actually talking about the fan that is in the smugglers box.
Old 04-22-2016, 02:01 PM
Fan.
Your post specified the condenser fan.
The one in your smuggler's box is your evaporator fan.
Try replacing your A/C relay/fuse.
G.
1986 911 Targa.
Only in L.A.:
Old 04-22-2016, 02:50 PM
ganun's Avatar
Just to be clear, the cond fan ONLY works with the ac on. As long as you don't turn on the ac you're ok. You have already unplugged the fan so there is no possibility of power getting to it inadvertently. When you replace it then do by all means install the in line fuse mentioned in a post above.
87 911 coupe, GP white, cashmere/black
64 Alfa Romeo Giulia TI - the violin
89 Peugeot 505 Turbowagon-other Pcar
67 912 coupe, white, sold
04 Audi Allroad 2.7T
Old 04-22-2016, 03:55 PM
I fought with my evaporator fan not working several years ago. Checked just about everything and could not find the problem. Until I ran across a blown fuse in the smugglers box, I don't remember where ecactly, but it was under the lip, up against a wall of the box, hiding just out of sight. Replaced it and everything started working just fine.
Now this is an '89, and I'm sure someone more knowledgeable than I could tell you if the same fuse exists on an '86, I don't know. I just thought I'd share my experience.
- Chris
Old 04-22-2016, 06:25 PM
Hi Opie,
Just open the windows and drive. You don't need any fan on that car at all except the big engine cooling fan. Lots of guys pull all their A/C stuff. You'll be fine until you can address the problem
Take care,
Dave
Dave McKenzie
1984 Carrera 3.2
1984 928S Automatic
2001 996TT
Old 04-22-2016, 07:02 PM
