-   -   shift coupler cone set screw - allen wrench size? (http://forums.pelicanparts.com/porsche-911-technical-forum/561470-shift-coupler-cone-set-screw-allen-wrench-size.html)
Kidasters 08-29-2010 01:13 PM
Hey Guys -
Did a search, and I couldn't find the answer. Just working on re-bushing the rear coupler, and I had a problem. The allen wrench that seemed to be the right size was 4 mm. However - when I finally got the screw out (and man - was that a challenge), the screw was stuck on it. I basically had to ruin it to get it off of my allen wrench. Is this the size everyone uses? I don't think I have a 5 mm allen, but is that the right size? What size does everyone use for this?
Please let me know.
Thanks,
Ken
Oh Haha 08-29-2010 01:30 PM
Use a machine screw with a socket head instead. Take the OE set screw to the local hardware store and match the threads to a new bolt. Yes, the head will stick up a bit as opposed to being countersunk but who cares?
I replaced my bungled up set screw with a 10mm headed bolt. A socket is easier to use in this application.
Flat6pac 08-29-2010 01:54 PM
4mm allen fits.
The early cars used a square headed bolt with a point and with a wire tie through the head
Bruce
