6 cylinder symphony
shift coupler cone set screw - allen wrench size?
Hey Guys -
Did a search, and I couldn't find the answer. Just working on re-bushing the rear coupler, and I had a problem. The allen wrench that seemed to be the right size was 4 mm. However - when I finally got the screw out (and man - was that a challenge), the screw was stuck on it. I basically had to ruin it to get it off of my allen wrench. Is this the size everyone uses? I don't think I have a 5 mm allen, but is that the right size? What size does everyone use for this? Please let me know. Thanks, Ken
'84 3.2 Targa '89 964 Coupe "What do you mean NEXT project?" - my wife |
Use a machine screw with a socket head instead. Take the OE set screw to the local hardware store and match the threads to a new bolt. Yes, the head will stick up a bit as opposed to being countersunk but who cares?
I replaced my bungled up set screw with a 10mm headed bolt. A socket is easier to use in this application.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
4mm allen fits.
The early cars used a square headed bolt with a point and with a wire tie through the head Bruce |
