shifting to 2nd
I am a new 83 Porsche 911SC owner and the car drives great except for when I shift from 1st to 2nd it seems like the shifter is a little resistant to go into 2nd. All the other gears are silky smooth. Am I doing something wrong? Should I push the shifter to the left or right?
Upshifting or Downshifting into 2nd? On the way up, try taking a short pause in neutral after coming out of 1st and before going into 2nd.
Downshifting, it may help to blip the throttle (if you're not doing that already). If you're already blipping the throttle, you may need to double clutch (blip the throttle with the tranny in neutral and the clutch out), before clutching and selecting second.
2022 GT3 Manual, 73 Carrera RS 2.9 Twin-Plug MFI Carbon Fiber Replica Former: 18 GT3 Manual,16 Cayman GT4, 73 911S, Two 951S's, 996 C2, 993 C2, BMW 635CSi Euro, Ferrari 550 Maranello, 06 Evo IX w/ many mods |
going from 1st to second - I'll try what you are saying. Sometimes it is somewhat smooth. Maybe it is just a touch/feel thing i need to get used to?
what is blip the throttle?
Blipping is when you hit the gas a little while you have the clutch in to bump the revs up, you might even be braking at this time too. This matches the rev between the engine and tranny, letting it shift easier.
Max Sluiter
Check out Vic Elford's High Performance Driving Handbook. There is a section on gear changing- double clutching, heel-toe, etc.
Pelican Parts.com - Porsche High-Performance Driving Handbook
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
This is a book I pull off the shelf and peruse again and again. Not only is it great for hp driving but there are some great tips on being a safer everyday driver.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
I changed the transmission fluid on my 79 911 from Swepco to Kendall NS-MP. Four quarts for less than $20. Noticeable results after 30 minute drive. After 200 miles, I thought I had a new transmission.
Andy Kay Kennedale, TX 817.948.8538 1979 911 SC Euro - Guards Red Last edited by 79 Euro; 03-16-2011 at 03:25 PM.. |
Blipping the throttle is better done with the clutch "out" while in neutral.....
Down shifting mantra from 3rd... "in/shift/out/gas , then in/shift/out/gas"........ momentary stop at "neutral" while doing this, with some gas "blip" assist. "In" = clutch to floor. if upshifting....you can "double-clutch" to take some load off the synchros.... shift into neutral form 1st, let up the clutch, then depress the clutch and continue into 2nd.
Wil Ferch 85 Carrera ( gone, but not forgotten ) Last edited by Wil Ferch; 03-16-2011 at 08:00 AM.. |
gearhead
While the 1-2 shift can never be hurried on a 915, revving the engine up to around 4000rpm in 1st gear helps.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
I have a similar issue on my car ('87 911) except it's a G50. When cold, shifting is a little notchy into 2nd and 3rd. After 10 min., it goes away. I've replaced the shift rod and cup bushings, and my transmission fluid was changed several months ago. I think the fluid was Mobil. Anything else to check out, or should I just accept it for now?
Alex ‘73 914 1.7 Phoenix Red '99 SPB #79 '16 Cayman GT4 GT silver Gone: '87 911 Blk/blk sunroof coupe, '13 991S Dbm/ag non-sunroof coupe |
Is the shifting any easier after you have warmed it up 5-10 miles at least? My'82 is a little grumpy 1-2 up shift when it's stone cold and OK once it warms up.
G. Hamilton '82 SC Guards Red-2nd time owned-Now sold "Bumerang" '70 TR6 N of Boston |
Also, adjust your shift linkage and check the shifter bushings. They may be failing. Cheap to replace. This made a big improvement in my 82SC. Here is the link to the Pelican Tech Article. TRY THIS LINK.
http://www.pelicanparts.com/techarticles/911_shifting_improvements/911_shifting_improvements.htm Have patience as you may need to perform the adjustment a couple of times to get it really good.
Jeff '82SC Pacific Blue '02 C4S Silver (Gone but fondly remembered) '11 GTS Amethyst |
Anyway
I always wonder why my 1969 Opel GT had a perfect shift my Astra F (price 500$) has a perfect shift fast and precise... and my 1980 SC has to be so reluctant shifting from 1st to 2nd and vice versa?
Paolo from Alps 1980 911 Targa SC 3.0 - Silver metallic 1980 Ducati Pantah 500 - Red 1989 Yamaha 500 "Tracker"
My 253,000 mile Corrolla shifts perfectly too.....don't ask this kind of question...
.. think instead... " A Stradivarious is hard to play".... ![]() Double-clutching works well to help....
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Max Sluiter
The synchromesh is a different design- that is the main thing, but I like Walt's answer better.
Try tightening/changing the tranny mounts as well as the engine mounts. I had a difficulty 1 to 2nd and after i put the car on the lift i noticed my tranny mount bolt was stripped from the previous service. Someone really messed it up when they tried to reinsert it. So i brought it to the shop and they fixed it. Now it's smooth. And i was even considering wevo shifter, not anymore.
The 915 is notorious for that...
My case was the synchro for 2nd gear - had to rebuild. If it "jumps" out of gear, then teeth are broken in the 2nd gear. In any case, its good to stall in N shifting up or down, drag-racing is not for the 915 :-)
My preferred concert venue? The driver's seat of an open-top 911. |
gearhead
Thx for the feedback, Matt. It's reassuring.
-Alex
